Problem with Cura
Ravilla
Posted · Problem with Cura
I have never had Cura before or used it and every version I try gives me an unable to start to error. I have try multiple different versions and cleared out my temp files as well to try and get it to work. Anyone know what causes this? I know there has been problems with the latest version but ive gone back to versions as far back as 2016 and still no luck with it working.
    This error happens in Windows when mixing up 32-bit and 64-bit applications.
    Two things you could try:
    * Don't install a new version of Cura on top of an old installation. So either select a different directory to install it to, or uninstall the old version first.
    * Make sure to install the Visual C++ Redistributable when the installer prompts you to.
    In short, I ask you to install Cura again.
    i uninstalled each version i downloaded before trying another version each time. I tried another version today and choose a different directory to install and still the same message as before popped up. It seems to get halfway thru the install process and then just skipped to be being done.
    Windows 8.1
    Processor: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz 3.40GHz
    RAM: 8 GB
    System Type: 64-bit Operating System, x64-based processor
    Intel(R) HD Graphics 4400
    I think it is the Intel Graphics chip that is giving you trouble. I have had nothing but trouble, even with high end programs, and that graphics chipset.
