KickahaOta 14
The Cura default print temperature is 225C vs. 200C, which seems worth making the adjustment. It's not a big deal, since Cura does have the support; it's just a bit of a pain to have to override the "Please switch from PLA to unknown" material-change prompt before each print.
gr5 2,098
The specifications appear to be extremely close to regular PLA when you look at softening temperature (it's around 52C - same as PLA), printing temperature, strength,etc. So I strongly suspect regular PLA print settings will be close enough until profiles come out.
