UM 2+ Cura 3.31 Missing profiles
cekuhnen
Posted · UM 2+ Cura 3.31 Missing profiles
Hi all,
I just installed Cura and noticed that for many of my nozzles of the Olson block the profiles are missing
For example below with the 0.8 nozzle only 0.15 layer height profile is present.
Is that normal?
Cura for Lulzbot has basically for each printhead multiple profiles (layer thickness) to choose from.
1632312762_ScreenShot2018-05-26at9_29_36PM.thumb.png.0b775cbefb5576290955626b62867ce6.png
    Yeah I don't like the 0.8mm profiles.  I recommend you start with the 0.4 profile and change line width to 0.8 and change layer height to whatever you want.
    However you can simply click that little "custom" thing next to the "recommended" box and then you can change layer height to whatever you want.  It's pretty easy to do.
