I unfortunately see this exact same issue. It may be related to how using a concentric pattern on top and bottom will also leave very specific gaps, causing a flat print to have "hinges" cause there's a gap through the entire print.
90% of the circles I print on 2 very different printers (Mendel90 and Ender 3) exhibit this issue, no matter the settings, originally in Cura 4.1.0, still happening in Cura 4.6.2 now.
Note the peg on the left.. it drew 3 very distinct, seperate lines that are much smaller than wall line width. Right hole, also gaps.
Top Posters In This Topic
22
17
12
12
Popular Days
Jun 6
30
Jun 4
17
May 27
9
Aug 19
8
Deve 22 posts
kmanstudios 17 posts
mnis 12 posts
burtoogle 12 posts
Popular Days
Jun 6 2018
Jun 4 2018
May 27 2018
Aug 19 2020
Popular Posts
ahoeben
This is going to be the least constructive reply ever, but each time I see this topic I think "I don't need to know about your leaky bottom".
mnis
And yes you can try another surface pattern, but it should still be seamlessly closed with any surface pattern. For example, I like concentric surfaces, but these are not properly closed in Cura v3.3.
kmanstudios
This is literally my method of troubleshooting: 1. Do as @mnis said: Make a test object and test it on all three machines to make sure results are consistent. This is most imperative as it may po
Posted Images
Adam324 13
When I have had this problem, heat or nozzle clogs have been the culprit often.
- I had the heat too high and filament was leaking out of the nozzle before it moved to the parts where there were larger travels to other parts.
- The heat was too low and the extruder had problems pushing filament out but that was also noticeable in other areas.
- Nozzle partly clogged... also noticeable in other areas.
If it is heat related for that one printer, Maybe the thermistor is not working properly and showing the temperature a lot higher or lower than what the actual temperature is. My thermistor has changed over 2 to 3 years and now the temperatures are about 10 to 15c lower than what it shows (Duplicator 9 printer). I have used a fluke meter with a temp sensor to check it over the years. (After realizing this awhile back, I have just adjusted my temperatures up 10 - 15c to compensate and finally recently ordered a new thermistor). Maybe your temps on that one printer are way off from the other printers.
At the end of the print, after the nozzle has cooled on all 3 printers, Is there a big difference with how much filament is hanging out of the nozzle with the printer that is having the problems? You need to use the same material of course on all 3 for the test with the same filament. I usually get about 10mm or so with my printer after it cools. That is specific to my printer, filament, and temps of course and can't be used for comparison to anyone else's printer. You are just trying to compare between your 3 printers though and use your other 2 printers as a reference.
If the temp reading is off and reading too high for the actual temperature, you will likely get a lot more oozing out of that 1 printer after the print. If that is confirmed, try reducing temps on that one printer by 5 degrees at a time and see if it helps. If it isn't oozing at all, then maybe try increasing the print temp by 5 degrees at a time.
