4 minutes ago, gr5 said:Could feature X already exist in Cura?
No, it doesn't already exist. The new bridge code does some acceleration stuff to try and stop underextrusion after a bridge wall line but there's no general ability. Some printer firmwares (Marlin, RepRap) have the pressure advance feature that modifies the extrusion rate to try and avoid fat corners due to low acceleration but that probably doesn't work when there's travel moves and/or retractions between the print moves so maybe an experiment is worth trying.
gr5 2,157
Yes. That makes sense to me. When you retract you relieve the pressure and when you un-retract it goes exactly back where it was (if it is fast enough). Retracting shouldn't actually suck filament up through the nozzle - that would add air inside the nozzle and be bad.
Feature X: So I was thinking the speed changes should be made more gradual in cura. When it's doing one shell and it knows the speed of the outer shell it should do a fixed seconds gradual speed change. Or maybe it should do a fixed distance gradual speed change. Say either 10 seconds or 300 linear mm? Or configurable? This thought was over a year ago.
Then I was printing something with these multiple speeds (default profile) and it looked to me like it was gradually slowing down before printing the outer wall. But I'm not sure if this is true. I looked at the part in layer view with colors for speeds and didn't notice anything. I didn't actually look at the gcode. Could feature X already exist in Cura?
