I am fairly certain I would have to anyway, as I dont remember any of the Builders to have an option for Serial_Port, My dilemma is where can I find the default settings for the UMO. As my latest searches have pointed me to the Ultimaker Marlin Branch in GITHub, which seems to contain the required Config file, my current question is, weather I should use the Ultimaker build or the latest Marlin build... The UltimakerMarlin branch does not seem to be very current, And I am unsure if the branch was made purely for the Configuration.h or if other files were modified as well...
Edited by bobIt depends on what you want.
Do you want an guranteed working Marlin for UMO take the version of Ultimaker.
If you don't mind some testing and trial and Error the mainline marlin can be made to work on the UMO.
I'd probably just try to merge the changes UM made to the config.h into the marlin mainline's version and build and see if it works first.
Amadee's builder seems to be working again. It is the last Firmware I used after I completed my Heated bed, It seems to be a branch from the Ultimaker branch, So I think I will use the configurator to build the configuration.h and then download the branch and build it manually.
Edited by bob
robinmdh 99
can't you just build with arduino?
it's only slightly more complex.
