Print with 0.1 and supports with 0.3. Does it already exist?
Posted
· Print with 0.1 and supports with 0.3. Does it already exist?
You can set the layer height for both wall and support for quit some time now in cura, but single extruder won't be able to give a reliable result seeing that both will need different temp settings.
You could use the temp setting for the walls as standard and then really slow down the speed for support to get that 0.3mm layer out the nozzle with that same temp for the 0.1mm wall ,but that defeats the purpose of optimization and the difference in pressure will be problematic also.
So unless you're using a dual extruder the difference of 0.2mm in layers is too much to get nice results.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
phantom 17
