But since OP is having trouble checking out the right repositories, I don't think OP has succeeded in building Arcus and Savitar (or CuraEngine) on Windows yet. (I know I still haven't, after 2.5 years of Cura development on Windows)
Edited by ahoeben
nallath 1,080
This is a screenshot of my setup.
ahoeben 1,654
You need all of Uranium, not just the UM folder. The UM folder should be in the PYTHONPATH when Cura is run.
I also have a "bin" folder at the same level as Cura and Uranium that contains CuraEngine.exe, Arcus.pyd, Savitar.pyd, and a bunch of runtime dlls.
nallath 1,080
The Arcus.pyd and Savitar.pyd aren't needed if you installed them with make install.
