How to reset parameters in a profile?
Arbitur
Posted · How to reset parameters in a profile?
I accidentally changed nozzle diameter in my profile and now when I activate different printers using the same profile the diameter doesnt change according to the printers settings. How can I remove ONLY the Material Diameter?
    In Cura, whenever you've manually changed a parameter, you should see a curved arrow next to the parameter's edit box. Clicking this arrow reverts the setting to its default, and causes the profile to no longer change that setting.
    Yes I know, but the setting is stored (It is IN the profile) so the revert arrow isnt displayed.
    Well, there's one surefire way to make whatever change you want to a profile:
    * In Cura, choose "Show Configuration Folder".
    * Exit Cura.
    * In the file-explorer window for the configuration folder, open the "quality" folder.
    * Locate the .cfg file for the offending profile.
    * Open it in a text editor.
    * (Carefully) make whatever changes you want. In your case, just find the line for the offending material-diameter setting and delete that line.
    * Save your changes and exit the text editor, and restart Cura.
    * Exit Cura.
    Thats what I was searching for Thanks. Would be nice with such a function in the GUI
    * Exit Cura.
    I followed your procedure, but my Quality folder is EMPTY .
    Not the best way, but maybe the easiest way:
    you can edit them with the printer settings plugin:
    Click "marketplace" in upper right of cura, make sure you are on "plugins", scroll down and alphabetically among the "P"s is "printer settings" plugin.
    * Exit Cura.
    Thank you for the tip, the config folder does not show in 4/80 Cura ?
