Posted
(edited)
· Cura simply not working after profile creation
@lfei and other Ultimaker people, there still seems to be a problem with the way Cura's saves/retrieves profiles. Not as bad as it used to be before 4.3.1 but it's still not working right. When you update a profile with current settings/overrides it saves most of the settings most of the time but it's not reliable as some settings may have changed randomly when that profile is loaded again. I still have to check them all the time because every now and again some value changes all by itself.
Tonight I had to interrupt my normal routine and print a small part in PLA using the recommended settings, and when I finished that job and continued with my "normal" work, I loaded my workhorse ASA profile. However suddenly it was unrecognizable. The following values were not as I saved them (I selected "discard" in case you were wondering.)
Layer height
Wall line count
Outer before inner walls
Z seam alignment
Infill density
Initial printing temperature
Final printing temperature
Retraction distance
Infill speed
Outer wall speed
Inner wall speed
Combing mode
Retract before outer wall
Enable print cooling
Build plate adhesion type
Dual Extrusion (all the settings there were different)
Slicing tolerance
Infill optimization
Enable coasting
NONE of the above settings were as I had saved them even though I've updated the profile bit by bit over the past few weeks to get it perfect. Now I have to re-do it all over again, just to re-do it again at some unexpected point in future.
Guys, my UM3 is not a toy, I'm trying to run a business here and can't afford to re-do stuff over and over again in Cura. Can you please help and sort this out, or if I'm misunderstanding the concept of profiles please explain it to me. The way I see it, if the grey star appears after I make a change, I have changed the profile and if I'm satisfied with my change I can update the profile and the star disappears, and next time I load the profile my settings will be back. If my understanding is correct, then I'm sad to say there is a bug and it's costing me time and sometimes filament if these changes happen and I don't catch them in time.
Patronus 3
