Aw, yes, that’s right...
Doesn’t “./cura marvin.stl benchy.stl” work?
2 minutes ago, ahoeben said:Doesn’t “./cura marvin.stl benchy.stl” work?
It does. It isn't exactly the same workflow as I have on the mac where I am able to throw parts over one by one as they get made by the CAD tool chain.
Now I will have to build all the STL files and then kick them to Cura in one go. I think I can work my way around it.
I just find it a bit strange the same program on two different platforms behave differently here, but well, not a biggie, the
--single-instance helped a lot.
ahoeben 1,849
I think the commandline argument you are looking for is —single-instance. That should connect to an already running instance and hand over the file to that.
mogul 0
--single-instance do indeed get me the same Cura instance. But unfortunately when I call it second time, it replaces the part, not simply adding to the build plate.
I want to print a Marwin and a Benchy at the same time.
I couldn't find an option for that. Can it be done?
