KickahaOta 14
People think that honeycomb is the strongest because bees do it. Evolution doesn't select for "the best". It selects for "good enough to get by." :)
Geometrically speaking honeycomb pattern an efficient use of 2D space when your trying to make an structure to house a bunch of basically round pupae. I think of it as circles packed tight, without the lost space between. I've never bothered with it due to all the jerking required to print.
My favorite infill for strength is Cubic. It is a triangular (also results in hexagons) pattern that on subsequent layers, each line also shifts, creating sloping line that form tetrahedrons inside your part. Since it is straight lines, it prints fast. It seems cubic would be the best candidate for gradual increasing infill (or support) as you print up. I say this because each new infill wall could be placed such that it has support starting off an existing infill wall. On the other hand, gradually denser grid or line infill (or other straight vertical infill), always result in a lot of unsupported overhangs at the start height of a new course. Am I making sense i that explanation?
Cubic Subdivision, Octet, and Quarter Cubic are similar in that the infill walls are sloped, and should also yield the same benefit to gradually increasing infill. I can't distinguish the difference between Octet and Quarter Cubic or between Cubic and Cubic Subdivision.
I would like to have honey comb too, but for design reasons - but that's another story... ?
On 6/21/2018 at 1:52 AM, KickahaOta said:People think that honeycomb is the strongest because bees do it. Evolution doesn't select for "the best". It selects for "good enough to get by." 🙂
that's why you were born KickahaOta 😉
Edited by samteolah
gr5 2,070
I'm not a UM employee but I really don't believe that honeycomb is stronger than all the other infills. Maybe you mean the strongest for it's weight? Certainly not the strongest for it's speed of printing. It's only strong in certain dimensions. Honeycomb is a bit weak on 2 of the axes I believe. I think the cube pattern that Cura has might be stronger than honeycomb for it's weight and also for it's speed.
Really the best infill is a gradual infill with higher density near all walls (side/top/bottom) and less infill in the center. Cura supports this.
Please try to draw a little bit of the honeycomb pattern on paper. You will see that you can't go very far at all in a straight line. The printer has to jig and jag constantly. Making it print very slow. There is a "triangle honeycomb" pattern that cura supports that is very similar to honcomb but prints much faster (all straight lines).
