Hi
Thanks for your reply.
Old build plate may be the problem with soldering.but after changing the new build plate also new buildplate got burned out..
1. Is there any possibility to burned out the build plate due to the power flactuation..??
2.we have upgraded hot end from ultimaker 2 to Ultimaker 2+ without updating the 2+ firmware is this the reason..??
Please help me out..I'm very much suffering with this issue..
gr5 2,331
I think "burned" may be a bad translation? This has nothing to do with heat.
This would be easy for me to fix. I would scrape off the covering of the trace to the right of where it broke. Then solder a wire from there to the connector and optionally cover the repair with kapton tape so there is no short circuit with anything else nearby. The other pads need to be resoldered to the board of course.
The cause of this problem is mechanical. the solder wasn't strong enough and when the first three pads came loose and the final pad was still sticking it doesn't take too much force to lift that copper trace off the board.
If you aren't familiar with how to repair this then you should be able to find a friend who is good with soldering who can fix it for you quickly.
