E3D V6 on UM2+ thermistor issue
Posted (edited) · E3D V6 on UM2+ thermistor issue
Hi Guys,
I'm trying to install an E3D v6 24v hot-end set on a UM2+ to be able to print Nylon filament at heigher temperatures.
This is the first time i'm doing a modification to the printer and I follow this guide:
https://wiki.e3d-online.com/E3D-v6_on_Ultimaker_2
supplemented with this video:
However since I only want to exchange the hotend and not the extruder I cannot use the supplied firmware (hex file) and gcode to write the EEPROM to my understanding.
So I downloaded the UM2.1 firmware on github (https://github.com/Ultimaker/UM2.1-Firmware) opened it in Arduino IDE 1.6.9 and made the adjustments in the configuration.h tab as instructed on the E3D guide, set the thermistor to type 5, adjusted the PID settings and the HEATER_0_MAXTEMP to 400.
Uploading to the printer through Aruino IDE seems to work well, in the advanced menu of the printer it reads the Version that I put in in the uploaded firmware.
However I did NOT do anything to the EEPROM, because when I connect the printer to Pronterface it reads out the values I changed in the newly uploaded firmware so I guess it is not neccessary?
Compiling and uploading the firmware to the Ultimaker seems to work but when I check the temperature in the advanced menu of the userinterface it says the current temperature is 8 degrees C while the bed temperature reading is 21C (correct). I measured the resistance of the E3D thermistor and it seems to be 113K ohms so it is not broken I think. When I raise the temperature of the nozzle manually in the advanced menu the Heater Cartridge heats up immediatly and after a few seconds I get a reading from the thermistor as well. However somehow I have the feeling that the cartridge gets a lot hotter then the thermistor says. As a test I changed back to the original thermistor of the Ultimaker and updated the firmware through the most recent version of Cura and than the temperature sensing seems to work as accordingly so I guess there's nothing wrong with the board either and the issue is purely software related.
Does anybody have an idea what I did or didn't do wrong?
Edited by BIKBart
    Posted · E3D V6 on UM2+ thermistor issue
    Update:
    I think I found the solution, I misread in the E3D guide that they use a PT100 temperature sensor instead of the standard 100k thermistor. It makes sense that the Temp1 input on the Ultimaker electronics board cannot handle a 100k thermistor out of the box because the electronics on the board are tuned towards the PT100 setup (which works on a different principle). So I took the original Ultimaker PT100 from the hot end and mounted it in the E3D V6, changed the temperature sensor parameter in the firmware back to option "20" which is the default setting and now the temperature readings are correct and the hotend heats up as quickly as the original. Time for a first test print :-)
    This topic can be closed if you ask me.
    • 2 months later...
    I'm running into this same thing, except, I'm wondering if I can use the e3d therm on the UM2 mobo?  Sounds like it's not possible without some adapter due to the way the electronics are designed.
    • 3 weeks later...
    I believe this is correct. It would be simpler to just use a PT100 sensor. You should be able to use the one that came with the UM unless you damaged it. The Ultimainboard's thermal sensor input is special amplifier circuitry designed just for PT100 type sensors.
    Edited by JRDM
    Thanks for clarifying JDRM,
    I just didn't realize the cartridge was the same size and shape since my old one failed and needed to be replaced anyway.  I got a new PT100 and the E3D is working great now.  It's nice to see somewhat of a standard in those shapes.
    Hi, I approached the problem differently and made another one that looks like the olson block only of aluminum.
    UM2-Hotend Drawing.pdf
    UM2-Hotend E3D v6.zip
    Edited by alexwimjan
    Hi Alexwimjan,
    That hot-end design looks great but why did you design a new kind of heaterblock for the E3D v6 if I may ask?
    Hallo,Because with this lookalike olson block you can use the original UM2 heating element and the temp.sensor. Also the connecting wires are on the back.  It works very well, I packed it with glass wool (insulation paper). I will take a picture soon.
    I have improved the attachment of the E3D by sliding a rip between it so that it can no longer turn around.
    Some foto,s.
    Between the hotend and the E3D there is also a TEFLON ring so that the hotend can be tightened properly.
    it is easy to change the nozel.
    1539527700816.thumb.jpg.c33cbe90b5d948a25947465a4d48cc08.jpg1539527700815.jpg.fb7258faba22adbd5fc890243842a416.jpg1539527700750-zwt.thumb.jpg.cfef662d084d1bab4c4e15e90e3160f0.jpg
    It asy
