CURA - Per model settings, limited choice
Posted · CURA - Per model settings, limited choice
When trying to build a tower of models and apply let's say different retraction settings, I found that there are many settings missing, although visible in the standard settings pane. Is it limitation of Cura or is there just some trick?
Thanks in advance for some hint!
    • 6 months later...
    Hey, I am looking for the same information as Hambinex. Is there a way to add per model retraction, or any other parameters that are not already in the per model settings panel?
    Thanks!
