kmanstudios 1,120
That round shadow is the priming tower location. When you use dual extrusion, it will pop up. You can turn it on or off at the dual extrusion tabs.
2
3 hours ago, kmanstudios said:That round shadow is the priming tower location. When you use dual extrusion, it will pop up. You can turn it on or off at the dual extrusion tabs.
Thanks! that fixed it.
ultiarjan 1,221
The shadows on the side is swown by cura as these area's can not be reached by the printer. If you print dual extrusion both nozzles need to be able to reach the area, therefore you loose a bit of space in dual vs single extrusion.
I'm pretty curious about the air printing..... can you replicate it? can you show a video?
