On 6/25/2018 at 7:05 PM, gr5 said:This is called a torture test for good reason. The filament doesn't get much time. You want to set the travel speed as fast as possible but it's going to string a little no matter what. These strings are pretty easy to remove by hand. One thing you can try is lowering the temperature. A lot. Maybe even as low as 180C but be careful as the filament gets more viscous and you might get underextrusion if you print too fast at 180C. You could also print with a smaller nozzle such as the .25. Make sure fan is at 100% but that's the default so you can't do much there.
I tried lowering the temperature to 185C, and still had stringing, but it was less than previously. I am looking at "Retraction Extra Prime Amount" on Cura, and notice that by default it is set to 0 mm^3. Should I leave this unchanged, or do you have a recommended volume?
gr5 2,330
