GregValiant 1,251
The Alta is a Delta printer? Then you won't be able to pass gcode files back and forth. Your Ender 6 is a Cartesian printer with the 0,0,0 origin at a corner. On a Delta printer the 0,0,0 origin is the center of the bed. They are going to want different speeds and acceleration settings as well.
You might be able to get the Alto to work with Cura though. Slice a calibration cube with Cura for your CR10 and then use the Silhouette software to slice a calibration cube for the Alta. Post both the gcode files here.
Edited by GregValiant
Top Posters In This Topic
15
13
8
8
Popular Days
Mar 22
5
Jan 1
5
May 5
5
Jan 10
4
jenny8008 15 posts
Mikeyfromindy 13 posts
CU_Ninjaneer 8 posts
GregValiant 8 posts
Popular Days
Mar 22 2022
Jan 1 2019
May 5 2019
Jan 10 2019
Popular Posts
tdpspt
Hello Everyone. I just signed up but I am not new here by any stretch of the imagination. I finally feel like I have something worth while to contribute to this ongoin
jenny8008
So, here we are again. These are my Cura-Settings for the Alta: The Start-Gcode: G28 ; home all axes G90 G1 Z5 F1200 G1 X0.000 Y-70.00 F2
jenny8008
Important: You have to remove the M104 and M109 commands from the Start-Gcode. These set the temperature of the nozzle and override the settings you've made! (Cura writes the custom temperature before
Posted Images
GregValiant 1,251
Printing a Gcode on different printers can be tricky. The printers must be near the same size (a print that fills a CR10 will not print on an Ender 3). The firmware must understand the G and M commands being sent to it. If you compare a Silhouette gcode with a Cura gcode you may be able to determine the differences. Some differences can be handled by altering the StartUp Gcode in Cura, but some differences can become incompatibilities and so you can't cross over.
Scottu99z3 0
The cr10spro has the auto bed leveling. And when I click on machine settings in cura I do have the starting and ending gcodes.
