Dim3nsioneer 557
It of course depends on the model you want to print, but the additional time on the UM3 is usually below 10% of the whole print length. If it is higher in your case, please have a thorough look if some settings (including speeds) are different between the two.
SandervG 1,521
You could speed things up, but since the print head is bigger and heavier, this will show in the surface quality of your print. So in general, an Ultimaker 2(+) is a bit faster than an Ultimaker 3. Both in acceleration/jerk and regular plain printing speed.
