Cura 3.4 Inventor import file name issue
ianeagland
Posted · Cura 3.4 Inventor import file name issue
Hi
The Inventor import works a treat on all objects tried so far.
There is one small issue. When you write the G code it does not pick up the file name imported. It writes to "unnamed.gcode".
Regards
Ian
