Posted (edited) · Bug in the generic materials files
I work on Cura 3.4 windows7 with an Anet A8 printer (1.75mm platic materials)
If I duplicate one of the generic materials (ABS as example on the picture below) there is a configuration error happening !
Do'nt click on the Reset Button or you'll loose all your settings !
This error involves the cartesio as you can see .
You can avoid this type of error by 2 ways
1) Remove the cartesio definition file in the definition folder of the cura ressources folder
2) Modify the generic material file, removing inside all the lines between the <machine> and </machine> tag
I think there is a conflict between the definition files and the generic material files
Edited by JCD
modify the text
