How can I find the logs? I opened Cura and went to Help -> Show configuration folder, but there is no Cura.log file there
Here is a link to the shared log file. https://drive.google.com/file/d/1CtJVY6ckW3DW3NIl7G5Vr_OEZ_XDFYst/view?usp=sharing
I should note that Cura freezes/crashes on me when I try to make setting changes to my printer, save gcode, or change the visibility on slicing settings. It happens no matter which printer profile I select, but especially when I select my "Custom FDM Printer" ("Hephaestus"). Also, if I save directly to my other printer's SD card there's no crash - only if I try to save direct to file.
I can't find anything obvious in the logs what could be causing this. There also isn't really a difference between saving to SD directly or you computer, just that it shows a nice popup to safely remove if you save to SD.
Is there anything/anywhere else I can check for crash data?
nallath 1,117
Please share logs. That should give us the info we need to debug it.
