OK. It's possible to increase the amount of concrete? 73.3386 / T.
On 7/5/2018 at 4:22 PM, jot4p said:OK. It's possible to increase the amount of concrete? 73.3386 / T.
Yes, there are various parameters that influence the extrusion rate. If you want to modify the extrusion rate without altering the line width or print speed then I would have thought that the Flow setting in the material section is the one to go for. By default it is 100% but you can make it larger or smaller and that will scale all extrusions.
But If I increase the flow from 100% to 200% the speed is 2x less....
Why is that?
1 minute ago, smartavionics said:Why is that?
The double amount of material for the same distance is equal to slow speed of x/y for the same speed of extruder.. I don't understand why is not increased the speed of extruder maintaining x/y speed..
burtoogle 509
No, the F600 applies to the X/Y movement only. So the move to those coordinates from the current position will take a certain amount of time, let's call it T. While that X/Y move is happening, the extruder will extrude 73.3386 units of concrete (in M^3, perhaps?!) and so the extruder rate will be 73.3386 / T.
