Currently using one of the UM2 Clone PCB's on my system, and replaced the 4988's with 2100's. It runs flawlessly.
I had to change the mode to Spreadcycle, which is about 10% louder than the Stealthchop mode, but the noise difference is still incredible compared to the 4988.
1
gr5 2,070
Unless you are amazing with removing surface mount parts and have all the fancy equipment that can heat just one smt chip enough to melt the solder and remove it and are willing to solder dozens of tiny wires to tiny pins then you can't do it.
Much easier to buy a smoothie board and replace the whole controller.
I think I saw some chinese umo+ PCBs that have removable steppers (socketed steppers) such that you can put in any stepper you want. These are UM clones. If you go that route buy 2 because I hear the quality control isn't great. But the price is impressive.
