Do some atomic pulls or cold pulls whatever it is called. If that doesn't work try a new 0.4mm nozzle (if you have one laying around).
https://ultimaker.com/en/resources/19510-how-to-apply-atomic-method
What kind of PLA are you using. 210C sounds right from most PLA, but I know MakerGeeks PLA prints at much higher temps. And I have heard of some PLA that prints at 190C.
I use this spiral thing to help with bed leveling.
https://www.thingiverse.com/thing:2996315
kmanstudios 1,073
The curling is because there is some sort of gunk on the tip of the nozzle that it grabs onto.
Your plate must be really super clean. I wash very thoroughly with soap and water. I use a dishwashing soap that cuts grease. And, that cleans the hands too. I rinse until my fingers squeak on the glass. Then I put it on the bed and clean with 99% Isopropyl alcohol to remove any stray minerals. THEN I apply a layer of PVA slurry. Glue stick with a wet towel wipe is the same thing. I am just a cheap bastich and recycle my PVA from my prints.
