Hi Gr5,
Thanks for your reply. Indeed we are using masking tape and we did clean the bed with alchohol before applying the tape. But when we print the models seperately the result is stuck very well to the bed. Do you think there having more models would somehow reduce the stickiness of the entire thing?
This particular print was done overnight, so we didnt see the error occur. We assumed that the accumulation of loose filament somehow ripped the entire print off the bed.
(I didn't have the time yet to watch the video you attached, but will do so over the weekend, thanks for the extra info)
gr5 2,330
It would be good if you saw the failure in action however...
It looks like the whole mess slid to the right at some point - does it go off the right edge of the glass?
So your basic problem is that your parts are not sticking well. What are you printing? PLA? Is that masking tape? If you use PLA with masking tape it's important to clean the waxy non-stick surface off first - use rubbing alcohol. If you are printing PP (as opposed to PLA or ABS) then tape is indeed good to use. Also wash with rubbing alcohol aka isopropyl alcohol. In USA this is found in any drugstore next to where they sell bandages. In europe it's a little harder to find. But you can use ethyl alcohol instead (also known as vodka).
However you have a heated bed! Okay you need to watch this whole video and become an expert at getting your parts to stick to the bed every time:
