Some filaments are better than others. Some filaments you can just lower the temperature and they won't string at all. Other filmanets - no matter how low the temperature it will make strings - but the lower the temp - the thinner the strings - until they are as thin as a spider web silk string and they are easy to remove afterwards.
Can you repost your picture in the ultimaker forums? USually I can click on your pictures to see larger version but not this one.
On the top left corner click on "gallery" then upload your picture to a gallery. Then make a posting and click on "my media" to insert the picture into your posting.
gr5 2,334
To reduce stringing look at the first picture:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
Every filament is different so I recommend you do the same test i did at different temperatures.
I have retraction amount at 4.5mm which is cura default and is the perfect amount. I also have one of these:
http://www.thingiverse.com/thing:46157
If you retract too much you will get air in your nozzle followed by blobbing.
