Dual Extruder - random M104 Commands
MachuRoberts
Posted · Dual Extruder - random M104 Commands
Hi Team! new to the forum, using Cura for a while.
Recently did a dual extruder upgrade - no matter how i seem to slice the file i am getting Gcode with random M104 commands to change the temperature throughout the print which is really screwing things up. For the life of me i cannot figure out where in my settings i am telling the temperature to change.
Trying to do a calibration cube (2 color)
loaded both models
assigned an extruder to each
merged the models
went through the settings for both extruders to make sure they are identical - and i get garbage Gcode (attached).
i have also tried merging then undoing to allow to control the "per model settings". same result
Tried on 3.4.1 and 3.3.1 same result which leads me to think its me!
CFDMP_20mm_Cube_B.gcode
    Please keep in mind your printer has two extruders and each of them has the temperature settings. If you want to set everything to the same temperature (maybe it's good to have the standby temperature a bit lower in order to avoid oozing?), don't forget the second extruder.
    • 8 months later...
    I'm experiencing the same problem, but only when using versions 3.6 and higher. The problem can be avoided if all the temps are set equal. However, it would be better if Cura would reactivate the current extruder after setting the previous one to standby temp. That can be done using the same command but using T1 instead of T0, if the current extruder is T1. For example, turn this:
    M82 ;absolute extrusion mode
    ; tool end script
    G92 E0
    G1 E-6 F10000    ; retract to prevent stringing
    ;G91        ; switch to relative positioning
    ;G1 Z1        ; travel +1 on z
    G90        ; switch to absolute positioning
    M82        ; ensure e is absolutely positioned
    G1 X24 Y15 {travel_speed}    ; move to 10 0
    ;G92 E0
    ;G1 E6 F2000    ; undo retract
    ;G92 E0
    ;G1 E-5 F2000    ; stage 1 of 3 stage retraction
    ;G92 E0
    ;G1 E2 F2000    ; stage 2
    G92 E0
    G1 E-58 F3000    ; stage 3, this keeps from producing "hair"
    G92 E0
    M83 ;relative extrusion mode
    T1
    ; tool start script
    G92 E0
    G1 E59.5 F2000                ; return - 1 to keep nozzle from oozing
    G92 E0
    M104 T0 S170
    into this:
    ; tool end script
    G92 E0
    ;G92 E0
    ;G92 E0
    ;G92 E0
    G92 E0
    G92 E0
    T1
    ; tool start script
    G92 E0
    G92 E0
    M104 T0 S170
    M104 T1 S200
