fbrc8-erin 234
I'm glad you were able to resolve it! Definitely important for the printhead shafts to be seated in the sliding blocks.
fbrc8-erin 234
Have you checked the axes alignment? If you pull the printhead to the front-center of the printer, and check the gap between your pulley and sliding block on the left-front and right-front sides, are they equidistant? It's possible for things to shift a little in shipping. If they have shifted, loosening the set screw on two opposite pulleys (I like to do it at a diagonal), and moving the printhead shaft/sliding blocks until they are equidistant again, should do the trick, then tighten the set screws again.
Edited by fbrc8-erinI have some more detailed instructions here.
mbhmirc 0
Hi thank you for your help, wierdly it was something similar but not quite. Two of the axis poles had jumped out of the sliding blocks ever so slightly. One we'd picked up on and put it back as it was nearly out however the other one had escaped out notice. Since it's gone it the layers are better and the odd angled items seem to have stopped. However i'll keep your guide for reference.
