Marlin Builder replacement
ginge
Posted · Marlin Builder replacement
Hi, not sure if this is the right place but here goes...
Hopefully the subject will have got past the "where can I get the Marlin builder" mental filters we all have now.
I had a free afternoon and needed to scratch a personal itch.
I have reimplemented the marlin builder to the best of my knowledge. All of the code lives in a single php file.
Check it out:
http://marlinbuilder.robotfuzz.com/
Source code:
https://github.com/ginge/marlin-builder
Please can you check this. I have done a quick check and it passes my initial "well it worked for me" test.
DO NOT USE WITHOUT MANUALLY CHECKING THE CONFIG. Sorry to shout.
It has a massive TODO list, mainly around sanity checking, validation checking (there is none), CSS and backend stuff
Cheers
Barry Carter
| http://www.headFUZZ.co.uk/ - Robotics Projects
| http://www.OpenServo.org/ - Full featured servo upgrade
| http://www.Openbiped.org/ - World domination
      • Introducing Universal Cura Projects in the UltiMaker Cura 5.7 beta
        • 10 replies
        This update is for...
        All UltiMaker S series
        New features
