A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
fbrc8-erin 270
You could also check the cables at the electronics board end of the printer, if you're comfortable with it.
You'll need to raise the build plate to get to the screws that hold the cover on so you can unscrew it and remove the cover.
