A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
DidierKlein 729
There is a setting that can help with this, it is known as elephant foot.
The setting is called horizontal expansion for the first layer, if you set it to a negative value like -0.2 it will reduce the effect you see.
(I'm not 100% sure of the setting name i'm not in front of cura)
Dim3nsioneer 557
Initial Layer Horizontal Expansion ?
covers911 0
Thanks to both. Yep, that's working perfectly.
