PETG Temperature
jofleck
Posted (edited) · PETG Temperature
Hey Together,
I ordered a spool PETG filament from 3djake.com own brand. On the spool there is a recommended temperature of 195-220°C. On the website they recommend 230-250°C. The Cura default CPE setting (240°C) is working well.
So printing too hot is not good due to toxic fumes etc.
So what is the best temperature to print with PET-G Filament? Maybe someone tried 3DJake filament yet?
Edited by jofleck
    Posted · PETG Temperature
    So the nylon presets are even hotter than the CPE settings. I tested to print the filament with 210°C and noticed that the layers are not sticking together. So the temperature label on the spool must be incorrect.
    Thanks ?
    I will be posting a two color PETG print soon. I wioll have cleaned up the supports and such, but it should give you an idea.
    And, yeah, I do not think 210 can really do PETG materials any justice to tell you the truth.
    Edited by kmanstudios
    I thought I would pass along a bit of philosophy that I use when using one material for an unlisted material.
    I go for a material that is slightly above rated temps for the unknown/unlisted material. This will always allow for the basic functions to work. Things like loading and moving, etc. Non printing oriented functions. There is nothing worse than a clog when it is not hot enough for a smooth flow during those ops.
    Since you can set the print temps and other factors such as retractions an other things in Cura for actual printing, that is where I exercise control over printing functions.
    So, I get to always have a smooth flow when performing filament ops because the temp will always melt the material and always get the actual printing settings I want within Cura.
    I like PET and CPE+ my my PET stock are MadeSolid PET+ when I run it on my UM3, I started with CPE+ black (which I also like to print just the smell gets to me) and changed a few things. temp is at 250 but prints well on 245degC with bed of 80-85 degC enclosed. preferred off fans for functional parts but 1-10% fan for making it look pretty. Also print at a lower speed @250 degC dont go over 40mm/s (to start with see if starts to skip steps or clogs/nozzle. I would start with that but you need to experiment with the settings as I am not sure of 3DJakes' PETG composition. I think UM2 should be able to handle it nicely but always check the couple they wear out fast at this temps and higher.
    Hope it helps.
    • Like 2
    Hope it helps.
    Here's the thing. This is a person who has found success with his choice of filament. AND, it is a great starting point. But, remember, it is a starting point. Great starting point, but a starting point nonetheless.
    So, if his settings do not work, it is not @jffry7's fault. He is passing on great info and should be looked at. I choose to be more general mainly because, well, I print weird stuff and what works for my strangeness, probably is not good for most 3D printing projects.
    But, this is an excellent starting point. :)
    • Like 2
    Agreed with @kmanstudios, which is why I mentioned you need to experiment. Thats how you will get your expected result. Those settings have been my go to start settings for 3 different printer. Full disclosure, 2 of them where on the 1.75mm filament. Out of 3, 1 was direct drive so i think you should be covered. First few tries will get you there so dont be discourage, mistakes are ok as long as you learn from them.
    5 minutes ago, jofleck said:
    Thanks guys ? Well, I think I have a lot to do the next weekend with playing around with my settings.
    Do not think of it as a lot to do. Think of it as a lot of play time :)
        • 4 replies
