Oh and the zits are sometimes associated with retraction but mostly with printing too fast. If you want your parts to look prettier you have to have patience and set *all* the printing speeds to 30mm/sec and if that fixe things speed it up slowly from there. You can play with the speed while it's printing in the TUNE menu but it's important that all the speeds are the same for the prettiest prints (no speeding up and slowing down as these cause under and over extrusion).
I will purchase some larger dessicant packs for the PVA and try it again after leaving it in an encolsed bag for a certain period of time.
The black was Nylon. I reduced the speed and upped the temperature and it has resulted in substantially less zits and better print quality, thanks for the advice!.
Once the pva is "damaged" by water no amount of desiccant will help. Or at least it would probably take months to get it dry again. Including resetting the dessicant 5 or 10 times during that time period. Instead you must heat it on the heated bed overnight under a towel at 80C to get it back to "good as new".
5 hours ago, Ztannem said:I reduced the speed and upped the temperature
Sounds good. Higher temperatures tends to result in more stringing/leaking but if it worked I'd stick with what worked.
gr5 2,094
You have two completely unrelated issues. Your PVA is underextruding badly. Your black plastic (is it pla? Or Nylon? It doesn't look like nylon) has some zits. I don't know if you care about those. The overhangs on your part aren't so great because the PVA did almost nothing.
PVA can absorb water pretty easily. If humidity is high, sometimes even in just the time it takes to do one print. Ultimaker PVA takes longer to absorb water than some other brands but leaving it on your printer for a few days is much too long if humidity is higher than 60%. Basically where 95% of humans live in the summer is too much humidity.
If the PVA has absorbed a lot of water it will snap crack pop and sizzle and you might see steam. The PVA will be snowy white and less transparent. Basically though if it is only *slightly* to wet it will look fine but won't print as well (similar to what I see in your photo). I suspect you need to dry it. I recommend putting it on the heated bed of the printer at 80C (no hotter!) with a towel over it for at least 2 hours to get the outer meter of filament (if you have a small print that only needs a meter or so of pva) and overnight to get most of the reel.
Then never leave it on the back of the machine even when printing - I keep it in a 2 gallon ziplock just open enough to let the filament out with a large dessicant pack (20 grams) that changes color when the desiccant needs to be reset (often).
