Mini Stepper Motor
Posted · Mini Stepper Motor
Hi Folks,
Yesterday I come across a small stepper motor, that might be used on the extruder itself, or for some other use..
The weight is 50 gram and length 30 mm with 4 mm shaft.
Not the smallest, but cost only 4 USD (500 Yen) so I bought 3 ea.
Here is a picture:
The "big" connector we are using on UM2 is shown beside the micro connector this mini stepper use.
Specs is found here: https://wakamatsu.co.jp/biz/products/detail.php?product_id=62020023
This stepper is made here in Japan.
Thanks
Torgeir.
  • Thanks 1
Hi Jakeddesign,
Just search amazon with this P/N and you find them for about 350 Yen..
I'd just saw them when I was looking for another suitcase.
(After 3 mounts here, you collect a few things..)
But I've still a week before returning home,. so..
Anyway, I found this at Akhihabara, the "electronic town" inside Tokyo..
Thanks
Regards
Torgeir.
    • 3 weeks later...
    They resemble steppers from old floppy drives? They had one to move the heads.
    For a direct drive of the filament, it would need a huge reduction gear to get enough torque, I think. But I like the idea.
        • 4 replies
