Thanks for the quick reply. I left the default which was Ultimaker 2 since I am not too familiar with the subject. Can I use a different flavor that will use the start gcode without affecting other functions? Marlin, RepRap?
tinkergnome 918
2 hours ago, tps2000 said:So, I tried putting "M92 Y82.05" in the "Start Gcode" field to scale it up using 80 steps/mm as the baseline.
The easiest way would be to write this line in a plain text editor, followed by a line with M500, save the file with the *.gcode" extension to the sdcard and "print" it.
This sets the steps/unit and saves it to the printers EEPROM. The benefits: no other things are affected and no need to change start gcodes or GCode-flavor.
set_ysteps.gcode
M501 ;read current parameters from EEPROM M92 Y82.05 ;set steps/unit for Y M500 ;save changed value back to EEPROM
Edit: a different deviation of x and y is usually a good sign that there is something else wrong with the hardware.
I would check for any mechanical issues. Perhaps are the axis not longer perpendicular to each other, or a sliding block or linear bearing is damaged, a loose pulley, or the belts have slack and needs to be replaced... such things...
Edited by tinkergnomeI tried "printing" the gcode file as you suggested and once again there was no change in the scaling. Mechanically there seems to be nothing wrong and this scaling problem has existed since the machine was new. It is unfortunate that the firmware doesn't allow for scaling. I have an inexpensive Creality CR-7 that has scaling parameters and it works perfectly.
I also tried changing the g-code flavor to marlin and added the start g-code and the results were the same, no change. I guess for now we are stuck with scaling the model in Cura each time.
ahoeben 1,654
What gcode flavour do you use? The default gcode flavour for the UM2+ is Ultigcode (mislabeled as Ultimaker 2 in Machine Settings). Ultigcode does not use start g-code afaik.
