I haven't experienced this error personally but according to the help text the next step would be to contact your reseller.
Before you do that, it might be worth a try to update the firmware to the latest version and reset to factory settings. If the board is not damaged, then a simple reset might help.
engr 2
What should I do next? Here are some screenshots of the temperature graph (I turned on and off different items in the legend) and also the event log.
