gr5
Thank you for the response.
I have it set to Ulticode and I get the same warning.
I also created a machine with reprap style and it creates the same warming (as expected).
Is there anything else I can look at?
Thank you.
gr5
Thank you.
@tinkergnome - any ideas on this? It shouldn't do this with ulticode, right? Find out what version of *firmware* you have. On the menu system of the printer.
On 9/4/2018 at 2:48 PM, Brion said:the firmware version si 15.05.5ex.
I'm not sure where this firmware comes from? It's probably quite old?
AFAIK the last version that came with legacy Cura was 15.04.6 - and the firmware that came later with Cura2 started with 2.x and so on.
But i may be wrong.... @gr5 did you ever heard of a version 15.05?
@Brion - just to be sure that we do not compare the incomparable...: can you upload the (Ulti-) gcode file that shows the warning message, perhaps someone else can have a look at it and try it on a different printer.
Have you compared the generated gcode file from your friend with yours? Perhaps can you upload his file as well.
I see that you have configured two machines in Cura, is this for a specific reason?
Hello,
I attached the G-code. The file named "DDG_plug2_top-only.gcode" is the file that works on my printer. I created the model but to get it to print my friend had to create the g-code on his computer and save it to my sd card.
The file with the name "DDG_plug2_top_only04Setp18.gcode" is the code I generated using my computer. I get the slicer warning with this code.
This morning I did an experiment by taking the file that will print and copying it and changing the name. I get the slicer warning with this file too. This file is named "G_code_that _will_not_work.gcode". I created this file by copying the "DDG_plug2_top_only.gcode" and saving it with the new name. I did this all in the Unencrypted folder.
With my latest experiment it seems the issue may be from my computer. Hopefully someone has experienced this issue before and has a solution.
I configured two machines. I made one reprap and one Ultigcode. I have deleted both machines and created a new one that is Ultigcode.
Thank you for your help.
6 hours ago, Brion said:The file with the name "DDG_plug2_top_only04Setp18.gcode" is the code I generated using my computer. I get the slicer warning with this code.
Well, if the problem suddenly appears after re-naming the (formerly working) file...
what happens if you shorten the name of your file to 26 characters (or less)?
Hello tinkergnome,
The result is the same if I shorten the name.
Thank you
gr5 2,099
That should be a warning - not an error.
In cura 15.X you can go into machine settings and you want "ulticode" style gcode.
In reprap style gcode you set certain parameters in cura. In ulticode you set certain parameters on the printer. Here is an incomplete list:
nozzle temp, bed temp, fan speed (on printer it's a multiplier so in ulticode mode you use both cura and printer to set fan speed and printer multiplies the fan speeds by it's set value - e.g. ABS I think is 50%), retraction distance, retraction speed. I forget what else. All of these should be in the materials settings on the printer.
Anyway - don't think of this as an error. Think of this as an optional way to print. for example if you have 3 um2go's like I do, I have a different bed temp for each one but that is set on the printer, not the slicer. So I can slice once and print it on any of my printers. There's no "right way" or "wrong way" to do this.
