15.04.6 was able to upload the firmware that 3.4.1 could not. Thanks tinkergnome! I wonder if adopters of the UM3,4,5 have the same issue when they go to Dual Extruders.
tinkergnome did you ever resolve the feeder motor direction between the old feeder and new feeders? I found a previous post that you made that has the difference in feedrate between the two feeders.
I may have resolved my own issue with feeder direction if this post is correct and I can toggle the direction of each feeder individually. This post was tough to find.
Fixed
Edited by michelideFixed
The issue that I now have is that in between using different extruders the printer moves towards the front left to the wall. I have to try the other version of the firmware "2"+ instead of "dual".
tinkergnome 926
5 hours ago, michelide said:The issue that I now have is that in between using different extruders the printer moves towards the front left to the wall. I have to try the other version of the firmware "2"+ instead of "dual".
That's more likely related to the gcode than to the firmware. Have you checked the gcode file for moves to x/y = 0?
Which slicer do you use?
Hi tinkergnome,
I am using Cura 3.4.1 with custom FDM printer with Marlin G Code (I also tried ultimaker 2 gcode with same result).
I did not previously check the file but just did by find *X0*, then find *Y0* in notepad. It doesn't appear to have any. The file is also attached here (Block Alignment 4.gcode) and an image of the file.
The start and end GCode that was placed in the file was default in cura 3.4.1. It wasn't something that I placed there.
tinkergnome 926
You can still use legacy Cura (15.04) to upload the firmware. Choose "Install custom firmware..." and select a *.hex file from wherever you want. You could even use "avrdude" from the command line, the Arduino (and Marlin firmware) doesn't depend on Cura.
