Another idea:
You have tried a "real" usb ethernet adapter, which is not working, because those adapters are to provide ethernet ports for notebooks for example.
But, there are also usb over ethernet adapter and these adapters normally connect only the wires together, without any logic inside. So you could use one adapter outside the enclosure to connect the ethernet cable to the usb passthrough and inside, vice versa.
It is just an idea, so no guarantees!
Smithy 1,141
I assume a normal ethernet cable will not fit between the enclosure and door? But there are also very flat ethernet cables you could try.
Or drill a hole in the enclosure ?
