Thank-you for responding
1-The USB did NOT show up
2-I switched to Wifi
3-It was working good and printed what I wanted
4-after awhile "print failed. carefully remove the print form from the build plate" showed up
5-since then I cant get it to do anything even with restarting it. I havent been able to use it for months. Everytime I turn it on it says the same thing "Print failed ect"
Let me know if I need to be more clear, i appreciate you trying to help.
kmanstudios 1,117
That is a bit vague. Can you provide details? Is it only that file? Was the USB bad? Did the USB even show up? When you say "It didn't go through," what does that mean? Did not start, did not show up in the print selection?
Kinda need details.
