UMO+ How to set LEDs always on?
PhilDesign
Posted · UMO+ How to set LEDs always on?
Hello,
I just recently add LEDs to my UMO+ and add the new software of the bultimaker to turn on the LEDs.
My only problem is, that I always have to turn them on manually.
Is it possible to change that, that there always on like on the UM2/+?
    @neotko Yes I use this firmware, to turn them on.
    But I looking for a way that there are on when I turn on the Ultimaker.
    Right now I always have to turn them on when I switch on the UMO by the UltiControll.
    Is there a way to set them to 255 when you powered on the UMO? (there set back to 0 when I turn on and off)
    Set the led range and ‘save’ current settings. Your led setting will be saved and used on the next turn on
    • Thanks 1
