Printing very small part
Rouzic
Posted · Printing very small part
Without actually seeing the model and what is missing, it is not possible to diagnose if it is a 'missing' part due to the lakc of Cura ability or model not being correctly made or if setting really need to be tweaked.
    • gr5 changed the title to Printing very small part
    Definitely turn off brim for this part.
    Also I agree that the issue is probably "coasting" and so it may print just fine.  Or maybe you need to turn off coasting or tweak it a bit.  I have never tried it myself.
    Thank you for all your answers!
    You're right, when I remove coasting the material deficiencies no longer appear in cura. it's a misleading representation of cura. When I display the displacements (coasting on), these gaps are represented as displacements.
    Thank you.
        • 6 replies
