Too much heat, poor cooling (?) ~ layers can't cool before next pass and they don't 'weld' together (and check/double check bed leveling) That has happen to me (on more solid pieces, so mostly bottom was like that), but learned to "KISS" it ? - "back to basics" - try a simple print with simple default settings, then tweak up slowly as you learn what works on your set-up/prints ?
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
kahuna3d 1
DF-Werkzeugservice 9
what material are you printing with? Which printer? Nozzle size etc...?
you could try to increase the flow rate.
