No/or wrong Monitor Tab info during print
kahuna3d
Posted · No/or wrong Monitor Tab info during print
Just printing adjustment knobs for my CR-10m, after the second print started I looked at the Cure window and the Monitor tab showed bad/wrong info, 100% done, 0 estimated time, print time is working, can abort/pause/ go to Prepare tab. Can't monitor, but printer printed the piece fine - closed Cura and relaunched - started printing a third piece and same thing happening, not sure how long into printing it does this as I'm busy "multitasking" ? - freaky man - It's printing now so don't want to disturb it -
Cura 3.4.1 / Mac OS X 10.9.5 / CR-10m / recommended slice set-up  - will likely delete Cura and prefs and reinstall, then print a test cube or something  -
Anyone seen Cura do this? ?
    Deleted Cura and prefs/cache and reinstalled - same issue and some new eerie stuff ?
    Fired up MatterControl and it printed the best adjustment knob I have ever seen without a glitch ?
    Cura was a bit funky from the get-go ?
    I can only summarized Cura 3.4.1 isn't savvy with Mac OS X 10.9.5 and CR-10  ?
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
