Anyone thought of creating a side purge bucket?
On 12/1/2020 at 4:58 AM, Garufa said:
Basically, I don't understand how your design work, but my design is try to not modify the metal parts, because they can help to hold the extruder in position and only allow it move up and down.
7 hours ago, Benleo888 said:Basically, I don't understand how your design work, but my design is try to not modify the metal parts, because they can help to hold the extruder in position and only allow it move up and down.
I hope this images can explain it better, sorry for not having more details before
@Garufa, @nvcheeko, @Benleo888
Sorry for that I repeat my question, but do all of you use 1.75mm filament?
Where can I find Hotends for 2.85mm or is there a description to modify the hotends?
Thanks for your help
4 hours ago, jtronics said:@Garufa, @nvcheeko, @Benleo888
1.75 only in my case. option you have is to install an UM3 head and always first pre-heat nozzle 2 on your start Gcode
Hi
Trying to learn about this mod :)
Are the changes to the metals parts I see mentioned in the thread needed for me to modify my UM2+ into DXU?
Or what are they actually needed for?
Thanks
On 12/7/2020 at 8:39 AM, X-Type said:Hi
Trying to learn about this mod 🙂
Thanks
If you arr talking about the mod I post before, the anwser is yes, mainly the metal heatsink for second extruder. However, for original UM2+, these extruder design with heatsink is already modify version and mainly for 1.75mm filament.
- 2 weeks later...
Hi guys!
I do really like this project!
Because of this project I started building a Ultimaker 2 extended.
But I was wondering, is there somebody out there thats is using the E3D V6 hotends?
I don`'t really understand the ones off ultimaker.
I have orderd two of them, but I now see i need more than just that. I also need those metal plates of the printhead: Printhead parts
Thanks!
- 3 weeks later...
On 12/21/2020 at 8:11 PM, stefan787 said:Hi guys!
Thanks!
Are there specific E3D V6 hotends for Ultimaker?
Is it possible to run higher temps with those?
On 7/21/2020 at 9:43 PM, alexjx said:I am.
Can you please share the firmware changes for the Duet to work with the DXU?
- 2 weeks later...
Ciao @yyh1002 I have inaccurate values in the temperature reading, it is possible to have the factory values for 24v 35w resistance and for pt100 temperature probe in order to compare them with those I have, I tried to do the PID config, the values are different between hotend 1 and hotend 2 is normal? in addition, I find that if I set the same temperature between the two hotends, the filament has a different viscosity, let me explain better, I mold with the same filament, same brand, same color, hotend 1 and 2, from hotend 1 the filament comes out beautifully fluid as it should be, while in hotend 2 less fluid comes out, but the temperatures are identical according to the display, at the moment I don't have an infrared thermometer to be able to check the real temperature.
Edited by dadoblu_2000
Top Posters In This Topic
43
14
14
10
Popular Days
Apr 3
8
Sep 13
6
Sep 23
5
Apr 7
5
yyh1002 43 posts
Garufa 14 posts
dadoblu_2000 14 posts
burdickjp 10 posts
Popular Days
Apr 3 2019
Sep 13 2020
Sep 23 2018
Apr 7 2019
Popular Posts
yyh1002
Hey guys, I would like to share a lever action dual extrusion solution I came up with for Ultimaker 2+. The approach is based on the great effort everyone put into Mark2 and Ultimaker
yyh1002
Some recent timelapse and photos of DXU.
Benleo888
Below the sample printing video with PLA+PVA after modification.
Posted Images
Garufa 2
Thank you for your design, I am trying a variation of it to keep the spring inside and not to reduce the cooling rings. please check the photos - if you modify the head bottom section to incorporate the spring adapter is even easier. let me know your comments. The drilling is easy and works great.
