1) All gcode files created by Cura 15.* have all the settings stored at the bottom of the file. Cura has a wonderful feature called "load profile from gcode" in the file menu. So find an old working gcode file and load the profile from that.
2) I suspect this is not a cura issue. I could be wrong. It is more likely a problem with data transfer to the arduino. If you print through USB then I suspect the USB cable. If you print through SD card then I suspect the SD card or the SD card reader has dirt in it (that happened to me - a hair in the SD card reader).
Is it possibly you changed something in machine settings (in cura)? If so then that won't get set back to the way it was if you load a profile. I suggest you print an old gcode file that you know works for sure and if I'm right (#2 above) it will also fail to print.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
gr5 1,506
Two things:
