Scoubidouille
Cura crashes at launch...?
Posted · Cura crashes at launch...?
Good evening everyone!
Have a problem running the latest 64bit versions of Cura!
I was using on an old PC running W7 32 bit an old version of Cura (15.xx 32bit version) found on the CD which my 3D printer was delivered with.
The proc on this old PC cannot handle 64bit version and I was willing to test the latest 64bit Cura....
So, I revived a (not so recent) machine (E6300 2GB, SSD 128 MB and a GeForce 7300 LE graphic card)  able to run the latest W10 64bit. Windows is running fine on it even if not a war machine!
On this machine, I installed the latest Cura (3.4.1) and at the end of the installation, as there was a tick in the "Lauch Cura at  the end of install" box, ...
So the Cura launched by itself, loading this and that, drivers and so on...then it crashed!
I ran again the software through the 'Programs' menu and it started normally...until it displayed a transparent windows just showing "User Agreement" (nothing else, no button to agree!). Then the Cura window  froze and I couldn't do anything more with it but moving the window and while moving it, the window multiplied itself  making hundreds of shadow windows...
The PC was still usable for other programs but that one was stuck with its bunch of "User Agreement" cloned windows ? the only way was to go to the Task Manager and kill the Cura task (showing 0% of use!).
After many tries and tests, I finally uninstalled CURA 3.4.1 then re-installed it but always got the same crash displaying the "User Agreement" Windows ...
I then downgraded to 3.2.1 for testing purpose and got exactly  the same problem.
I browsed the forum to find something that was close to my problem and found nothing but an thread explaining that we could find Cura logs in %APPDATA%.
I found both logs (Cura 3.4.1 - even if uninstalled!!-  and one from Cura 4.2.1 and both had as the last line: User did NOT agree to the User Agreement" :
"2018-09-19 23:48:33,595 - INFO - [(4768)-MainThread] UserAgreementPlugin.UserAgreement.didAgree [41]: User did NOT agree to the user agreement"
(see attached file of one  of the log below).
Sure I didn't agree to the agreement and I would like to have been able to do it!!! but HOW, I don't have the hand to do so ???!!!
I gave a quick look at the log files and didn't find any obvious mistakes/errors/informations that could help me correct it .
Does anyone have an idea of what can happen?
While reading the logs, I saw there was a lot of lines correponding to graphics commands/drivers loading and I thought it might come from the old graphic card (7300 LE - only Directx9 able).
I know it was a hard work to find the good drivers for it under W10 (which didn't recognized it at first) but the graphic card doesn't make any problem with the other installed  programs (but none of them are graphic intensive programs).
Anyway, a big thanks in advance for any clue you could give me to circumvent this problem and let me run this latest CURA!
PS1: As you guessed, English is not my mothertongue. Don't hesitate to ask for more details if I'm not as clear as I thought! ?
PS2: I found another graphic card in my shelf (an ATI 5450 1GB, not the most recent card in the market but able to run DirectX 11 in case this is part of the problem!
!!). I'll try to change the 7300 LE to this 5450 to see if any improvment occurs and will let you know soon...
Have a good night!?
cura.log
Share this post
This could very well be a driver issue, so let us know if switching to the much newer ATI fixes it.
Share this post
Thanks for your answer!
I too believe it could be a driver problem even if I have no obvious clue to thinking so....
Unfortunately, the ATI HD 5xxx card ...seems to be dead (at least the DVI output I used!) and didn't display anything (may be the reason it was at the bottom in the drawer!). I'll try it later on another monitor (the card has also a HDMI and a VGA output).
I put back the GeForce and am now looking for some cheap card to have a try with something better handled under W10.
I'll keep you posted!
Share this post
I am experiencing the exact same problem. I've just had to reinstall Windows 7 64 bit on my Dell laptop and I can't get the latest version of Cura to load. Not even sure it's installing properly, because when the progress bar gets half way across it finishes. All my drivers are up to date and it used to work, although annoyingly slowly.
Share this post
@poddy71, there is not much we can do to help without the logs.
For crashes and similar issues, please attach the following information:
  • (On Windows) The log as produced by dxdiag (start -> run -> dxdiag -> save output)
  • The Cura GUI log file, located at
    • %APPDATA%\cura\<Cura version>\cura.log (Windows), or usually C:\Users\\<your username>\AppData\Roaming\cura\<Cura version>\cura.log
    • $USER/Library/Application Support/cura/<Cura version>/cura.log (OSX)
    • $USER/.local/share/cura/<Cura version>/cura.log (Ubuntu/Linux)
If the Cura user interface still starts, you can also reach this directory from the application menu in Help -> Show settings folder
Share this post
Posted (edited) · Cura crashes at launch...?
Well, I ordered a GT 710 graphic card (DirectX 11 capable and launched in 2016) and  I should receive it on next friday. If changing the card solve the problem, I think it could be the drivers. Let's see what's happening.....
(BTW, I tried the HD 5450 on 2 other desktops and it is defintily DEAD!)
Edited by Scoubidouille
Share this post
Here's my log files in plain txt
Cura Log:
Quote
2018-09-27 07:54:53,823 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin FileLogger
2018-09-27 07:54:53,932 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin FirmwareUpdateChecker
2018-09-27 07:54:53,953 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin GCodeGzReader
2018-09-27 07:54:53,974 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin GCodeGzWriter
2018-09-27 07:54:53,995 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin GCodeProfileReader
2018-09-27 07:54:54,045 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin GCodeReader
2018-09-27 07:54:54,066 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin GCodeWriter
2018-09-27 07:54:54,095 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin ImageReader
2018-09-27 07:54:54,118 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin LegacyProfileReader
2018-09-27 07:54:54,140 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin LocalContainerProvider
2018-09-27 07:54:54,173 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin LocalFileOutputDevice
2018-09-27 07:54:54,198 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin MachineSettingsAction
2018-09-27 07:54:54,222 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin ModelChecker
2018-09-27 07:54:54,249 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin MonitorStage
2018-09-27 07:54:54,277 - WARNING - [MainThread] UM.Preferences.getValue [91]: Tried to get the value of non-existing setting cura/active_mode.
2018-09-27 07:54:54,283 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin PerObjectSettingsTool
2018-09-27 07:54:54,312 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin PostProcessingPlugin
2018-09-27 07:54:54,335 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin PrepareStage
2018-09-27 07:54:54,375 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin RemovableDriveOutputDevice
2018-09-27 07:54:54,431 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SimulationView
2018-09-27 07:54:54,465 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SliceInfoPlugin
2018-09-27 07:54:54,490 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SolidView
2018-09-27 07:54:54,517 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SupportEraser
2018-09-27 07:54:54,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin Toolbox
2018-09-27 07:54:54,592 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin CameraTool
2018-09-27 07:54:54,621 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin MirrorTool
2018-09-27 07:54:54,654 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin RotateTool
2018-09-27 07:54:54,691 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin ScaleTool
2018-09-27 07:54:54,717 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SelectionTool
2018-09-27 07:54:54,749 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin TranslateTool
2018-09-27 07:54:54,798 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin UFPWriter
2018-09-27 07:54:54,838 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin UltimakerMachineActions
2018-09-27 07:54:54,971 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin UM3NetworkPrinting
2018-09-27 07:54:54,999 - INFO - [Thread-3] UpdateChecker.UpdateCheckerJob.run [34]: Checking for new version of cura
2018-09-27 07:54:55,007 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin UpdateChecker
2018-09-27 07:54:55,086 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin USBPrinting
2018-09-27 07:54:55,108 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin UserAgreement
2018-09-27 07:54:55,151 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade21to22
2018-09-27 07:54:55,179 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade22to24
2018-09-27 07:54:55,209 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade25to26
2018-09-27 07:54:55,237 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade26to27
2018-09-27 07:54:55,264 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade27to30
2018-09-27 07:54:55,288 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade30to31
2018-09-27 07:54:55,316 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade32to33
2018-09-27 07:54:55,340 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin VersionUpgrade33to34
2018-09-27 07:54:55,366 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin SimpleView
2018-09-27 07:54:55,410 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin X3DReader
2018-09-27 07:54:55,459 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin XmlMaterialProfile
2018-09-27 07:54:55,490 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [431]: Loaded plugin XRayView
2018-09-27 07:54:55,545 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [124]: Looking for old configuration files to upgrade.
2018-09-27 07:54:55,556 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,564 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,569 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,575 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,580 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,586 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,591 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,596 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,602 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,608 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,613 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,618 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,624 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,630 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,635 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,641 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,647 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,653 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,659 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,665 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,671 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\cura.log, skip it
2018-09-27 07:54:55,677 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\packages.json, skip it
2018-09-27 07:54:55,683 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\plugins.json, skip it
2018-09-27 07:54:55,689 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [275]: Failed to get file version: .\uranium.lock, skip it
2018-09-27 07:54:55,702 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [177]: Socket state changed to Listening
2018-09-27 07:54:55,738 - INFO - [MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.4\CuraEngine.exe
2018-09-27 07:54:55,743 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [94]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 3.4\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Ultimaker Cura 3.4\\resources\\definitions\\fdmprinter.def.json', '']
2018-09-27 07:54:55,940 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [empty_definition_changes] added.
2018-09-27 07:54:55,946 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [empty_variant] added.
2018-09-27 07:54:55,952 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [empty_material] added.
2018-09-27 07:54:55,958 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [empty_quality] added.
2018-09-27 07:54:55,963 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [empty_quality_changes] added.
2018-09-27 07:54:56,238 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend]
2018-09-27 07:54:56,267 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] Cura_SteamEngine version 3.4.1
2018-09-27 07:54:56,291 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] Copyright (C) 2018 Ultimaker
2018-09-27 07:54:56,310 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend]
2018-09-27 07:54:56,319 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [181]: Socket state changed to Connected
2018-09-27 07:54:56,320 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] This program is free software: you can redistribute it and/or modify
2018-09-27 07:54:56,326 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [171]: Backend connected on port 49674
2018-09-27 07:54:56,329 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] it under the terms of the GNU Affero General Public License as published by
2018-09-27 07:54:56,336 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] the Free Software Foundation, either version 3 of the License, or
2018-09-27 07:54:56,341 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] (at your option) any later version.
2018-09-27 07:54:56,351 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend]
2018-09-27 07:54:56,358 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] This program is distributed in the hope that it will be useful,
2018-09-27 07:54:56,363 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2018-09-27 07:54:56,370 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
2018-09-27 07:54:56,378 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] GNU Affero General Public License for more details.
2018-09-27 07:54:56,384 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend]
2018-09-27 07:54:56,390 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] You should have received a copy of the GNU Affero General Public License
2018-09-27 07:54:56,406 - DEBUG - [Thread-8] UM.Backend.Backend._backendLog [94]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
2018-09-27 07:54:59,937 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [103]: Select build plate: 0
2018-09-27 07:54:59,943 - INFO - [MainThread] cura.CuraApplication.run [677]: Initializing variant manager
2018-09-27 07:54:59,951 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [52]: Loading container ultimaker_s5_glass
2018-09-27 07:54:59,960 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [ultimaker_s5_glass] added.
2018-09-27 07:54:59,961 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [52]: Loading container ultimaker_s5
2018-09-27 07:55:00,674 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [248]: The definition cache for definition ultimaker_s5 failed to pickle.
2018-09-27 07:55:00,680 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [ultimaker_s5] added.
2018-09-27 07:55:00,689 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [67]: Exclude variant [empty_variant]
2018-09-27 07:55:00,690 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [52]: Loading container ultimaker_s5_aluminum
2018-09-27 07:55:00,699 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [ultimaker_s5_aluminum] added.
2018-09-27 07:55:00,708 - INFO - [MainThread] cura.CuraApplication.run [681]: Initializing material manager
2018-09-27 07:55:00,865 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pva_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,871 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_hips_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,877 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pva_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,884 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_abs_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,889 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_nylon_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,894 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_arnitel2045_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,899 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pva_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,905 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_novamid1070_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,910 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_petg_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,917 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pla_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,925 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_nylon_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,930 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_nylon_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,936 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pla_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,942 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_petg_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,949 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pc_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,954 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_abs_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,959 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_petg_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,965 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pc_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,970 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_arnitel2045_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,976 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pla_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,981 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_novamid1070_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,985 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_abs_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,991 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_novamid1070_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:00,997 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_pc_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:01,003 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding dsm_arnitel2045_175_cartesio_0.8mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:01,008 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_hips_175_cartesio_0.4mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:01,014 - WARNING - [MainThread] cura.Machines.MaterialManager.initialize [230]: Not adding generic_hips_175_cartesio_0.25mm_thermoplastic_extruder to the material manager because the variant does not exist.
2018-09-27 07:55:01,019 - INFO - [MainThread] cura.CuraApplication.run [686]: Initializing quality manager
2018-09-27 07:55:01,042 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [145]: Lookup tables updated.
2018-09-27 07:55:01,047 - INFO - [MainThread] cura.CuraApplication.run [691]: Initializing machine manager
2018-09-27 07:55:01,055 - INFO - [MainThread] cura.CuraApplication.run [694]: Initializing machine error checker
2018-09-27 07:55:02,111 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [256]: Creating post processing plugin view.
2018-09-27 07:55:02,127 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [BQ_PauseAtHeight] added.
2018-09-27 07:55:02,133 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131778040] added.
2018-09-27 07:55:02,133 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: BQ_PauseAtHeight
2018-09-27 07:55:02,159 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [ChangeAtZ] added.
2018-09-27 07:55:02,164 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131779496] added.
2018-09-27 07:55:02,165 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: ChangeAtZ
2018-09-27 07:55:02,175 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [ExampleScript] added.
2018-09-27 07:55:02,181 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131779776] added.
2018-09-27 07:55:02,182 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: ExampleScript
2018-09-27 07:55:02,191 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [FilamentChange] added.
2018-09-27 07:55:02,198 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131824104] added.
2018-09-27 07:55:02,199 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: FilamentChange
2018-09-27 07:55:02,215 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [PauseAtHeight] added.
2018-09-27 07:55:02,222 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131898448] added.
2018-09-27 07:55:02,223 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: PauseAtHeight
2018-09-27 07:55:02,234 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [PauseAtHeightforRepetier] added.
2018-09-27 07:55:02,240 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131778264] added.
2018-09-27 07:55:02,241 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: PauseAtHeightforRepetier
2018-09-27 07:55:02,250 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [SearchAndReplace] added.
2018-09-27 07:55:02,255 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131931776] added.
2018-09-27 07:55:02,256 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: SearchAndReplace
2018-09-27 07:55:02,273 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [Stretch] added.
2018-09-27 07:55:02,280 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [131982560] added.
2018-09-27 07:55:02,281 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [155]: Begin loading of script: Stretch
2018-09-27 07:55:02,481 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [172]: Loading theme file: C:\Program Files\Ultimaker Cura 3.4\resources\themes\cura-light\theme.json
2018-09-27 07:55:02,653 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [244]: Loaded theme C:\Program Files\Ultimaker Cura 3.4\resources\themes\cura-light
2018-09-27 07:55:02,730 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [263]: Post processing view created.
2018-09-27 07:55:03,066 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [52]: Loading container fdmprinter
2018-09-27 07:55:03,629 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [248]: The definition cache for definition fdmprinter failed to pickle.
2018-09-27 07:55:03,639 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [369]: Container [fdmprinter] added.
2018-09-27 07:55:03,675 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel.
2018-09-27 07:55:03,680 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [20]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
2018-09-27 07:55:03,685 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [50]: Updating QualityProfilesDropDownMenuModel.
2018-09-27 07:55:03,690 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [55]: No active GlobalStack, set quality profile model as empty.
2018-09-27 07:55:04,368 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getColor [101]: No color black defined in Theme
2018-09-27 07:55:04,817 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:19: TypeError: Cannot read property 'stageId' of null
2018-09-27 07:55:04,821 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:104: TypeError: Cannot read property 'stageId' of null
2018-09-27 07:55:04,826 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Topbar.qml:175: TypeError: Cannot read property 'stageId' of null
2018-09-27 07:55:04,831 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:433: TypeError: Cannot read property 'mainComponent' of null
2018-09-27 07:55:04,836 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:427: TypeError: Cannot read property 'mainComponent' of null
2018-09-27 07:55:04,841 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:465: TypeError: Cannot read property 'sidebarComponent' of null
2018-09-27 07:55:04,846 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/Cura.qml:497: TypeError: Cannot read property 'sidebarComponent' of null
2018-09-27 07:55:04,866 - DEBUG - [MainThread] UM3NetworkPrinting.DiscoverUM3Action._createAdditionalComponentsView [166]: Creating additional ui components for UM3.
2018-09-27 07:55:04,941 - DEBUG - [MainThread] UM3NetworkPrinting.DiscoverUM3Action.startDiscovery [39]: Starting device discovery.
2018-09-27 07:55:05,023 - DEBUG - [MainThread] UM.Controller.setActiveStage [164]: Setting active stage to PrepareStage
2018-09-27 07:55:05,297 - DEBUG - [MainThread] cura.Machines.Models.GenericMaterialsModel._update [23]: Updating GenericMaterialsModel.
2018-09-27 07:55:05,302 - DEBUG - [MainThread] cura.Machines.Models.BrandMaterialsModel._update [86]: Updating BrandMaterialsModel.
2018-09-27 07:55:05,308 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [32]: Updating NozzleModel.
2018-09-27 07:55:05,373 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel.
2018-09-27 07:55:05,475 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [301]: file:///C:/Program Files/Ultimaker Cura 3.4/resources/qml/SidebarHeader.qml:546:9: QML : Binding loop detected for property "width"
2018-09-27 07:55:05,528 - DEBUG - [MainThread] UM.Controller.setActiveView [97]: Setting active view to SolidView
2018-09-27 07:55:05,536 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [97]: Creating model checker view.
2018-09-27 07:55:05,548 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [106]: Model checker view created.
2018-09-27 07:55:05,550 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [77]: Creating dialog [MoreInfoWindow.qml]
2018-09-27 07:55:05,660 - DEBUG - [MainThread] cura.CuraApplication.run [723]: Booting Cura took 20.14615225791931 seconds
Share this post
DxDiag Log:
Quote
System Information
Time of this report: 9/27/2018, 07:50:45
       Machine name: ANDY-PC
   Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr_escrow.180815-1700)
           Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
       System Model: Inspiron 1545
               BIOS: Phoenix ROM BIOS PLUS Version 1.10 A14
          Processor: Pentium(R) Dual-Core CPU       T4200  @ 2.00GHz (2 CPUs), ~2.0GHz
             Memory: 3072MB RAM
Available OS Memory: 3032MB RAM
          Page File: 2582MB used, 3479MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: Mobile Intel(R) 4 Series Express Chipset Family
       Manufacturer: Intel Corporation
          Chip type: Mobile Intel(R) 4 Series Express Chipset Family
           DAC type: Internal
         Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02AA1028&REV_07
     Display Memory: 1292 MB
   Dedicated Memory: 32 MB
      Shared Memory: 1260 MB
       Current Mode: 1366 x 768 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: LGD6E01
        Native Mode: 1366 x 768(p) (59.973Hz)
        Output Type: Internal
        Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.1994 (English)
     Driver Version: 8.15.10.1994
        DDI Version: 10
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 11/6/2009 23:04:16, 5620224 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B78E66-6902-11CF-5274-A022A7C2C535}
          Vendor ID: 0x8086
          Device ID: 0x2A42
          SubSys ID: 0x02AA1028
        Revision ID: 0x0007
 Driver Strong Name: oem3.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.1994:pci\ven_8086&dev_2a42&subsys_02aa1028
     Rank Of Driver: 00E60001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (High Definition Audio Device)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_76B2&SUBSYS_102802AA&REV_1003
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            Driver Name: HdAudio.sys
         Driver Version: 6.01.7601.17514 (English)
            WHQL Logo'd: Yes
          Date and Size: 11/21/2010 04:23:47, 350208 bytes
            Other Files:
        Driver Provider: Microsoft
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Microphone (High Definition Audio Device)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: 2.4G Wireless Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x3938, 0x1031
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2939
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: ?
 Free Space: 105.0 GB
Total Space: 152.5 GB
File System: NTFS
      Model: TOSHIBA MK1665GSX H ATA Device
      Drive: D:
      Model: TSSTcorp DVD+-RW TS-L633B ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
     Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E4
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&D1
   Driver: n/a
     Name: Intel(R) ICH9M LPC Interface Controller - 2919
Device ID: PCI\VEN_8086&DEV_2919&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&F8
   Driver: n/a
     Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E2
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&D0
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_02AA1028&REV_93\3&2B8E0B4B&0&F0
   Driver: n/a
     Name: Intel(R) ICH9 Family PCI Express Root Port 2 - 2942
Device ID: PCI\VEN_8086&DEV_2942&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E1
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&EA
   Driver: n/a
     Name: Dell Wireless 1397 WLAN Mini-Card
Device ID: PCI\VEN_14E4&DEV_4315&SUBSYS_000C1028&REV_01\4&2B17F6E0&0&00E1
   Driver: n/a
     Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E0
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E9
   Driver: n/a
     Name: Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4354&SUBSYS_02AA1028&REV_13\4&1B809680&0&00E2
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&D8
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&E8
   Driver: n/a
     Name: Mobile Intel(R) 4 Series Express Chipset Family
Device ID: PCI\VEN_8086&DEV_2A43&SUBSYS_02AA1028&REV_07\3&2B8E0B4B&0&11
   Driver: n/a
     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&D7
   Driver: n/a
     Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&FB
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_2A42&SUBSYS_02AA1028&REV_07\3&2B8E0B4B&0&10
   Driver: n/a
     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&EF
   Driver: n/a
     Name: Intel(R) ICH9M/M-E 2 port Serial ATA Storage Controller 2 - 292D
Device ID: PCI\VEN_8086&DEV_292D&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&FD
   Driver: n/a
     Name: Mobile Intel(R) 4 Series Chipset Processor to DRAM Controller - 2A40
Device ID: PCI\VEN_8086&DEV_2A40&SUBSYS_02AA1028&REV_07\3&2B8E0B4B&0&00
   Driver: n/a
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&D2
   Driver: n/a
     Name: Intel(R) ICH9M/M-E 2 port Serial ATA Storage Controller 1 - 2928
Device ID: PCI\VEN_8086&DEV_2928&SUBSYS_02AA1028&REV_03\3&2B8E0B4B&0&FA
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.19091
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.19091
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.19091
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7601.19091
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7601.19091
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.19091
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.19091
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7601.19091
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7601.19091
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.23709
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.19091
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.23709
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.23709
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.23709
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.23709
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.19091
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.23709
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.23709
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.23709
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.19091
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.23709
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.23709
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.23471
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.23709
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.23709
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.19091
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.23471
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.23471
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.23709
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.19091
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.19091
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.19091
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.23471
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.23709
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.23709
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.23709
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7601.23285
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.23709
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.23709
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.23709
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.23471
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.23709
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7601.19091
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7601.19091
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7601.19091
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.23709
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7601.19091
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7601.19091
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.23709
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.23709
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.23709
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.23709
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.23709
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.23709
Audio Capture Sources:
Microphone (High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.19135
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.19135
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.19135
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.23709
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.23709
WDM Streaming Capture Devices:
HD Audio Microphone 2,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
Integrated Webcam,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
WDM Streaming Rendering Devices:
HD Audio Headphone/Speakers,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.19135
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.19135
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.19135
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.19135
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7601.23709
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.23709
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.23709
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.23709
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Share this post
Hi Everyone!
Better late than never, I have had no time until now to retry CURA with the new graphic card.
So this evening, after installing all the GT710 drivers (Nvidia listed drivers only for GT720 and upper! ??), I lauched CURA 3.2.1...and it started like a charm and I was eventually able to see  the "User Agreement" screen and accepted it.
I then used it for one hour without any problem.
I will now upgrade to Cura 3.4.1 but I'm sure I will have no problem with it.
I still don't know why the (rather old) previous graphic card was not handling correctly (as it was working fine with every other applications until now) but I suppose either the drivers were not correctly set for W10 (they were W7 drivers) or may be a lack of recent DirectX support from the GC?
Anyway, all is well which ends well!
Thanx to all of you and specifically to ahoeben!
S.
Share this post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
    • Ultimaker Cura 4.0 | Stable available!
      Ultimaker Cura 4.0 is mainly focused on the improved user interface and cloud integration.
      As always, we want to collect your user feedback for this release. If there are any improvements you can think of, feel free to mention it here and help us to shape the next release.
      • 96 replies
Important Information
Welcome to the Ultimaker Community of 3D printing experts. Visit the following links to read more about our Terms of Use or our Privacy Policy. Thank you!
