cloakfiend 996
I didnt remove the usb. I simply reloaded the filament as im noticing a lot of uneven layer lines and wanted to reprint the model using my off the roll method to see if its tension on the spool or dirt on the screw. Both my last files somehow became corrupted?
Edited by cloakfiend
RaimonElctrncs 0
Did you safely removed the usb? If your using one ?
