Add code before each new layer
varazir
Posted · Add code before each new layer
Hello,
I have been googled and I can't find a solution to add a code line before each new layer.
Nothing obvious option in the post script plugin.
Number 2 is that I want that permanent and not needing to add it for each printout.
Why you may ask ? I like the Octolaps plugin in Octoprint and it has some cool ways to take a screenshot but no easy way for each new layer.
It has option to take a screenshot on "change in z" but if you have z-hop enabled it will take each time it does a hop an not just for new layer.
I like to add SNAP before each new layer.  How do I always do that ?
TIA
Daniel
    5 minutes ago, ahoeben said:
    See this conversation:
    Thanks but they are talking about the post script plugin. It's not going to work as I needed it to permanent basis.
        • 4 replies
